miss and knocking noise when it is reved up in neutral
Old Jul 10, 2023 | 07:00 PM
Reneemb's Avatar
Unhappy miss and knocking noise when it is reved up in neutral
1988 Mazda RX7 1.3L Rotary GXL S4 2nd Gen
I really need some help. Here is the breakdown.
5/8 - took car in for squish brakes and radiator leak an exhaust leak - This is what was done - New Manual trans driveshaft, new radiator, new exhause Y pipe, midpipe, gaskets, new brake caliper front pass side (had other side fixed a few months before)
As I was driving it home started to make a loud knocking noise - turned around and took it back - Ran a engine compression test and was above min standards - healthy engine
6/3 - A new clutch kit was put in, clutch slave cylinder
Car is still making noise
June 20 - rechecked engine - good shape, checked fuel injectors and swap out ignition coils, checked crank angle sensor, air flow meter, belts and pulleys, pressure senor, throttle position senor, fuel pressure and ecu. All good.
Still making noise. PLEASE TELL ME SOMEONE KNOWS WHAT IS WRONG! I was told I could pick it up or leave it there longer and they will try to look into some more.
Help! Renee
amanda3134
Feb 16, 2023 04:17 PM
NewbieGad
Feb 14, 2023 02:54 PM
LoopDeDoop
Jul 2, 2021 08:38 PM
j0ffr37
May 21, 2021 03:46 AM
MichaelMazda
Aug 23, 2020 02:59 AM
