I need help!!!!!!!!!
Old Apr 22, 2005 | 07:10 PM
DEFcon's Avatar
Default I need help!!!!!!!!!
I just bought a 1987 RX7 Turbo II (stock) a couple days ago and the only problem with it is that its starts fine when its is could but when its hot and try to start it, it will not crank over although it gets close. I fear that the motor might be losing compretion and i have to get a new motor or rebuild it. It was just replaced by Mazda in 1999 and it hase only about 13k - 15k miles on it. If some one could get back to me A.S.A.P. that would be awsome and greataly appreciated
Old Apr 26, 2005 | 11:59 AM
bgerg's Avatar
Default RE: I need help!!!!!!!!!
yep! go and check out the posts in general tech, under starting issues, by superloudrx7 that will answer your question.
Old May 7, 2005 | 09:26 PM
Killerb's Avatar
Some if not most 2nd gen rx-7's had this problem due to high fuel pressure levels causing the injectors to bleed off excess pressure when shut off. My rx had bleed off kit that a local Mazda tech installed in it as a recall at one time. Madzdatrix has a bleed off kit that can be installed or duplicated.
Old May 15, 2005 | 02:51 AM
krazzyrpm's Avatar
Sir,
I can maybe help you. I am part owner of Krazzy Rpm Racing a small up and coming shop in Hesperia,Ca. We specialize in Rotaries. Give us a call. 760-949-4424
Metalmunkeez
Jun 21, 2011 06:19 PM
Stevoh
Jun 21, 2010 03:17 AM
