Airbag flashing light
Old Dec 23, 2007 | 03:15 PM
ej40s's Avatar
Default Airbag flashing light
Hi. My 1993 RX7 airbag light blinks 6 times in a row then a pause and then starts 6 blinks and keeps repeating the cycle.
Any ideas?
Thanks in advance!
Old Dec 24, 2007 | 07:59 AM
Mazmart Trini's Avatar
Default RE: Airbag flashing light
Per the workshop manual, there is either a damaged driver-side air bag module or poor connection of the clock spring connector.
Old Jan 12, 2008 | 02:39 PM
ej40s's Avatar
For a person not very good in mechanics what do you suggest? How can I be sure which one is the problem? Airbag module...is that like the computer that controls the unit or the actual airbag that's on the steering.
Thanks!
Old Jan 12, 2008 | 10:46 PM
sstlaure's Avatar
The airbag module is the actual airbag itself (center of the steering wheel.)
Not sure if you want to mess with that yourself. That's a pretty old airbag. Make sure you disconnect the battery if you do, and don't stand in front of the airbag when you're working on it, always sit the airbag module with the back face (surface that mates to theinner steering wheel)to the ground so that if it inadvertantly deploys, it doesn't become a projectile (bag pushing into ground and launching it)
Theclockspring connector is the actual connector behind the airbag that runs the voltage up the column and into the airbag module.
Diamond02
May 30, 2014 01:36 PM
djn
Oct 9, 2011 03:00 AM
ppd121
Dec 31, 2006 04:41 AM
whitecolamazda
Apr 12, 2006 12:30 AM
jjalilvand
Oct 21, 2004 05:50 PM
