5th and 6th ports ???
if i wired the 5th and 6th ports open would i get more hp n tq? n where will i get it in the rmp range low, mid, or high ? or if i did wired them open would i loss power? PLEASE HELP
hi if you leave these port open all the time it will not affect your low speed driveability. because these ports are only active after half throtle. meaning that theywill only see air flow after you've opened the secondary throtle plate. the only thing that my acure is a small flat spot at around 3.5 thousand rpms, due to athe transition between the fuel injectors primary and secondary.
bbarons1
Feb 9, 2011 12:29 PM
