White spark plugs, no lean code, pinging
Old Aug 28, 2019 | 09:28 AM
Fhritp's Avatar
Default White spark plugs, no lean code, pinging
Hey all. 2003 mazda protege5 running lean. No codes. White plugs. Confused af.
Checked fuel pressure. 35 psi at idle, 45 psi with FPR vacuum line disconnected, system holds 30 psi when key shut off.
Tps reads .6 volts with throttle closed and up to 4.5 volts WOT, smooth transition with no dropouts
MAF signal at 2.2 volts at idle goes up to 3 volts at about 4000 rpm
Intake Manifold Vacuum tested holding steady at 20 in-HG Suggesting no vacuum or manifold gasket leaks
Any tips? Stumped.
Any suggestions from here.
Old Aug 29, 2019 | 03:58 AM
What makes you think its running lean?
Old Aug 29, 2019 | 02:07 PM
gbh's Avatar
gbh
I think based off of spark plug inspection. OP, please post pic of plugs.
woodysca
Dec 15, 2014 08:02 PM
93greenstrat
Jan 29, 2013 10:27 PM
mzdaspd304
Apr 12, 2009 02:39 PM
ontheair
Nov 6, 2008 03:09 PM
Gherrin
Sep 23, 2006 12:30 PM
