Tube is cut, need help figuring out what it is
1 Attachment(s)
2003 Mazda Protege5. This tube is cut and seams to be leaking air while the engine is on. I can't find an engine bay diagram to find out what this tube is. Any ideas on what it is/does? Would it be okay to just wrap it with tape?
I am not a protégé expert, but that line looks like it's a vaccuum line going to that round item on the left which looks a brake booster. How's your brakes feeling. Wrap it with tape to get somewhere to get the part and put in on when you get there. Phone for part first. Wait for tanprotege to respond he's the protégé expert.
(Post 136879)
Originally Posted by Snakkub
(Post 136880)
The brakes feel fine. My car was recently towed twice in the last 2 weeks. They replaced the battery and the alternator belt. I opened up my hood and found this tube leaking air. A friend said that this could be the brake booster or the cruise control actuator, neither of which i know anything about. Is this something I can just tape up with electrical tape or send back to the shop?
2 Attachment(s)
(Post 136881)
I would use a lot of tape, drive it there and leave it til fixed. You may want to e-mail them the pic and make sure they get part first, cause it would be easy to change as you wait.
And im not sure if this has anything to do with this problem, but my car has an automatic transmission and when the car is parked and idling whatever is underneath the shifter is rumbling. It sounds like everything underneath it is shaking rapidly. no problems while driving though. |
Snakkup: go to a auto parts store and get a length of this tubing for a couple of bucks. Put it in and it's fixed.
That shaky idle will be better as well. |
(Post 136899)
Indirectly it is the alternator. It tells me the alternator is good. When you use an electrical devise the alternator kicks in to deliver the juice, powered by the idling engine. The idle speed controller keeps keeps the engine from dying. It raises the idle speed and that calms down the engine vibrations.
Make sure the battery cables are properly attached. Make sure the grounding wires and straps are attached with good clean contact areas. Make sure the cables on the alternator are properly attached. Treat the engine as if it had rough idle concerns. Run a good fuel system cleaner through the tank. https://encrypted-tbn2.gstatic.com/i...EbVyorXlA3RXhT It's 10 years old: give it new spark plugs and wires (if it has wires). Just basic tune up stuff. Wait for Noggin to take over he is the basic tune up expert. That includes replacing the pcv! |
(Post 136910)
Just basic tune up stuff. Wait for Noggin to take over he is the basic tune up expert. That includes replacing the pcv! First we would need to know much more info as per this thread: https://www.mazdaforum.com/forum/new...-avatar-30905/ I'm sure he could go by many things from this thread by Tanprotege which is Protégé based: https://www.mazdaforum.com/forum/maz...%E9g%E9-31136/ Most things pertain to any engine, and yes the PCV valve is my pet peave with Mazda's because it's not ever on there schedule to check it. Years ago this valve was changed every year. Another pet peave is people leaving fluids in too long. Such as: so called lifetime tranny fluid, power steering fluid, coolant, brake fluid. Another good thread on general maintenance and care for your car: https://www.mazdaforum.com/forum/gen...-engine-30949/ |
