transaxle pump leaking
Old Jan 25, 2009 | 01:30 AM
19Protege95's Avatar
Default transaxle pump leaking
I just bought a 95' Protege that has some trans fluid leaking from the auto transaxle pump/cover, I would like to replace the gasket (310 in pic below) but I dont know if there is anything behind the cover that can spring out, etc.. Is this a simple gasket replacement like a valve cover (unbolt & take off) or will there beparts falling/flying out when the cover is removed? I found a pic that shows what looks like a spring behind it but I'm not sure, actually I dont know if its just a separate cover (510) or the entire pump (500) that comes off..any help would be appreciated..thanks
Old Jan 25, 2009 | 07:26 PM
Default RE: transaxle pump leaking
Old Jan 25, 2009 | 07:58 PM
Or perhaps this cover is not the pump shown in 500 and just a left side round cover??
Old Jan 25, 2009 | 11:03 PM
hixx's Avatar
Nothing will spring out on you.There is a shaft that goes from the torque converter to the pump but its just splined on both ends.You can remove it or leave it.
Old Jan 26, 2009 | 06:54 PM
thanks for the reply, i figured something had to spin the pump (671) but didnt know what surprises to expect when pulling that pump cover off. I hope there is enough clearance from the body to back that pump cover off the case without having to drop the entitre transaxle. The reason i say is that round splined cylinder that the shaft's spline mates with in the center of the pump housing looks like it could be at least 3" deep. i just snagged a service manual off fleabay so it should elaborate on everything. would you say this is about a 45 minute on vehichle job? thanks again!
Old Jan 26, 2009 | 07:29 PM
hixx's Avatar
It will if you put a jack under the crossmember and unbolt it then lower it with the jack.
Old Feb 9, 2009 | 11:00 PM
anybody know the torque specs for the pump bolts?
carts78
Mar 8, 2008 07:58 AM
webrumor
Oct 31, 2007 07:35 PM
heathersprotege
Sep 14, 2007 08:00 PM
tRp
May 15, 2007 01:05 PM
Atl Phil
Apr 18, 2007 10:32 PM
