Protege with PO335 code
Old Nov 13, 2007 | 10:18 PM
trekpsycho's Avatar
Default Protege with PO335 code
I have a 1996 Protege LX 1.5L with an automatic transmission that I bought used. The MIL light was on when I bought it. It had a code for the MAF sensor (which I have replaced along with the hose from the MAF sensor to the throttle body) It also has a PO335 code: Crankshaft position sensor A circuit malfunction. I have changed the sensor and checked the wiring all the way to the PCM for open circuits with an OHM meter. I have also checked the clearence between the sensor and the crank pulley. I can't get the code to go away. When I erase it, as soon as I crank the engine and raise the speed above an idle, the MIL light comes back on and the same code is given. Does anyone have any ideas on what I can check next to resolve the PO335 code? Is it possible that the PCM is bad? If so, does anyone know where I can get an after market or used PCM? The only place I have been able to find one is the dealer and the price is outrageous!
Thanks.
Old Nov 14, 2007 | 08:18 AM
Mazmart Trini's Avatar
Default RE: Protege with PO335 code
What is the last 8 of your Vin? I can then check to see if we have a PCM in stock for your car.
Old Nov 14, 2007 | 09:47 PM
trekpsycho's Avatar
I will check and post it tomorrow.
Thanks.
Old Nov 14, 2007 | 09:50 PM
trekpsycho's Avatar
Nevermind, here it is: T0318119.
Thanks.
Baston-Rob
Dec 25, 2011 04:48 PM
Bobbygian
Sep 30, 2010 09:07 AM
kd5hmy
May 21, 2006 11:46 PM
FOSTER1234
Apr 14, 2006 10:36 PM
91300zx
Apr 11, 2006 05:03 PM
