PO171 and PO401 codes Help please!
Old Jul 22, 2007 | 07:11 AM
Carl333's Avatar
Default PO171 and PO401 codes Help please!
Newbie here. Read and read for hours here today.
Protege 1999 1.6 stock 70,000 miles Symptoms- Exhibiting poor acceleration, stuttering on the get go, doesn't seem to take its gas, choking. Does not stall and idles pretty smoothly.
Check engine light (for 2 years) on and the codes read as follows as of today:
PO171- bank one system too lean
PO401- EGR Flow Insufficient Dectected
This is what I have done so far.
PO401- Trying to reslove the PO401 problem, I removed the EGR and found that the valve was jammed in the closed position. After spraying several times with cleaners and manually openning and closing the valve, I finally freed it and is opening and closing freely without much resistance. Reinstalled. Above symptom is the same.
PO171- MAF Mass Airflow Sensor removed and sprayed for 10 seconds with contact cleaner. It didn't clean well. I still see some dirt but didn't want to touch the 2 wires in fear of breaking them.
Changed plugs 20,000 miles ago and looked at one plug and clean as a whistle.
Checked hoses for vacumn leaks and none that I can see.
Going into the garage to test fuel pressure, maybe change fuel filter. Perhaps change o2 sensor 1st one before converter
1- Am I on the right track?
2- Did I miss anything?
3- What is a watergate actuator and how do I test if necessary?
Thank you for your responses.
Old Jul 22, 2007 | 04:53 PM
Carl333's Avatar
Default RE: PO171 and PO401 codes Help please!
Cleaned the MAF and the EGR and my car is running like a charm. 60 miles and no CEL. YAAAAA!!!!
simmonsp5
Sep 21, 2023 04:49 PM
jcr_iv
Aug 12, 2011 08:20 PM
jcr_iv
Aug 12, 2011 08:19 PM
mge_1
May 21, 2009 01:42 PM
eli
May 27, 2008 08:54 PM
