P2006 on 2003 Mazdaspeed Protege
Old Aug 29, 2020 | 06:59 PM
leftydog1961's Avatar
Default P2006 on 2003 Mazdaspeed Protege
Intake Manifold runner control stuck closed, bank 1
Anyone seen this b4? I checked vacuum hoses for leaks, removed a few electrical connectors and sprayed them with cleaner, but have no idea where the runner is? i've looked by the intake manifold but don't see anything obvious. Is it hidden by airbox? thanks for any help!
Old Aug 30, 2020 | 03:06 AM
Intake runner is inside the manifold. There will be a vacuum operated actuator on the side. With a solenoid sending vacuum to the actuator.
Old Aug 30, 2020 | 02:20 PM
Default P2006
excellent! Ok! What do I have to do to fix this. Please don’t say remove intake manifold. Obviously the vacuum is not working or hose is broken, or solenoid is broken.
solution? Can I force it open externally, any picture of what it looks like external? The Mazdaspeed has NO room to even see near the intake manifold. Thanks!
Old Aug 31, 2020 | 07:22 AM
If you unplug the solenoid, and supply 12v + & - to the terminals, you should hear it click. Also either before or after adding power you should be able to blow thru the solenoid, and not be able without power.
Secondly, with the engine running supply engine vacuum directly to the actuator on the manifold and A: see if it moves & B: does the engine idle & sound change?
Old Aug 31, 2020 | 07:30 AM
Default P2006
Not sure where the vacuum solenoid even is. Little room to see anything. Pic? What part do I need or can I just put a screw in to open it up?
Old Aug 31, 2020 | 03:36 PM
is this the item you are mentioning?
Which terminal gets + and witch gets -?
Old Sep 1, 2020 | 06:06 AM
Yes that is the solenoid. Shouldn't mater which terminal gets + or -. It just needs +&- to activate.
Old Sep 1, 2020 | 06:09 AM
Default P2006
can I just get this part at autozone, etc.
is it expensive? Thanks
Old Sep 1, 2020 | 06:10 AM
Price unknown as I'm not in the USA.
Old Sep 1, 2020 | 06:11 AM
Most parts stores will have a listing
