Oil Leaking Problem?!?!
Old Nov 30, 2013 | 05:12 AM
  #31
Juanky's Avatar
the gasket for the cat is metal.do not use any sealants there. just clean with thinner.
Old Nov 30, 2013 | 05:32 AM
  #32
Juanky's Avatar
the gasket for the cat is metal. do not use sealant there. just clean with thinner. do not make your life complicated by trying to replace the one that goes at the flange with the spring bolts. thats a conical one. im not sure if it is a conical one made of asbestos or what. i did not replace that. just try not to hurt it. i did not even clean it.
Old Nov 30, 2013 | 11:06 AM
  #33
bdo3043's Avatar
Well I got the three bolts out... Only half of it from the cat because all three of them broke halfway and the other three are stuck in there. Jaunky is it possible to pm with your number so we can text its a hassle for me to come and down from the garage everytime haha
Old Nov 30, 2013 | 11:40 AM
  #34
bdo3043's Avatar
Wow I am really stupid, the reason why they broke because I was tightening them instead of loosing it now it is broke half way in is there a way to get them out?
Old Nov 30, 2013 | 01:02 PM
  #35
Juanky's Avatar
cool!!!! you just made things more interesting!!!! yes, it is possible to remove them. you just need a bolt extractor and a correct drill bit. can get both at home depot or such, whatever is close to your house. dont worry. just take a sample bolt with you so you can buy the correct extractor and new bolts. for now, just put some pb blaster on them while you go get the extractors. or if you can grab them with a vise grip, you might be able to get them out. just be careful which way you turn them.
Old Nov 30, 2013 | 01:14 PM
  #36
Juanky's Avatar
wait.... if my memory does not fail me, those are supposed to be studs. you only removed the nuts. if they broke, then the easy way out in this case it to try remove them with a stud extractor(if you have some of it to grab) or just drill them and use new bolts with nuts and lock washers. that is probably what i would do. easy to do because the cat will be out of the car. now, be careful with that oxygen sensor, you dont want to damage it.
Old Nov 30, 2013 | 01:43 PM
  #37
Juanky's Avatar
and yes. feel free to text me.
Old Dec 1, 2013 | 08:30 AM
  #38
bdo3043's Avatar
I will post pictures in a few hours with my progress, I will not be able to finish because I will be out of town for two weeks, thanks much to Juanky for the help on the forums and phone!
Old Dec 1, 2013 | 05:25 PM
  #39
Juanky's Avatar
you are welcome
Old Dec 8, 2013 | 09:23 PM
  #40
bdo3043's Avatar
2 out of 3 studs broke because I was tightening them instead of loosening it on the bottom of the cat
The oil pan bolts that came out, stick with anti sealant on the threads that was on there since 1999... It's going to be a pain the the butt to remove
My baby in the garage until I come back home from the business trip, at least its not in the below 0 weather outside!
My new exhaust flange because the one connect to my Walker exhaust pipe was in pieces when I removed it
Underneath the cat as you can see the the 2 studs are still intact as they are broken, well at least the filter is clean!
The old exhaust pipe, as you can see the hole where the spring bolts were suppose to go broke off as it was thin and rusted
Removing the cat from the top because drilling out the studs from the bottom was tiring. The nuts where very tight but thanks to my breaker bar and some PB spray, it was a breeze!
The stiffner that was blocking my oil pan, this was a pain in a butt to remove because I had to remove my whole exhaust pipe and this to get my oil pan out
My new walker exhaust pipe!
My tools/work area/bolts waiting for me to come back and be used!
