NEED HELP! 94 Protege
Old Jul 6, 2007 | 11:15 AM
MasterMynd's Avatar
Default NEED HELP! 94 Protege
My 94 Protege is having a starting issue. Sometimes when I turn the key it jsut clicks, it can take anywhere from 2 or 3 turns up to 15 minutes of just turning the key on and off before it starts. When it does start, it starts like nothing was wrong. Other then that the car runs great and has 217K on it. I have replaced the ignition switch, the starter and still hasn't fixed the problem. Anyone had the same issue or know what else could be causing the problem?
Old Jul 6, 2007 | 07:21 PM
wsoape281's Avatar
Default RE: NEED HELP! 94 Protege
sounds like a bad ground wire. just jiggle the ground wire off of the neg. side of the battery the next time that it does this and it should fire right up. the fix is to just clean up all of the contacts on the ground wire and bolt it on tighter
lukek33
Jun 11, 2009 12:15 PM
Pradamuimui
Jan 10, 2009 04:33 PM
carts78
Mar 8, 2008 07:58 AM
dwamp2006
Aug 20, 2007 08:04 PM
fnjww
Jul 21, 2007 05:18 PM
