Mazda Z5-DE - Airconditioner Problem
Old Jul 2, 2020 | 12:54 PM
JnrMazda's Avatar
Default Mazda Z5-DE - Airconditioner Problem
Hello !
I have aircondition problem in my mazda with Z5-DE engine.
When i push AC button, nothing happens. Does mazda have some common known failure spots on AC system ?
I havent diagnosed it more, but i will look into it soon.
Old Jul 3, 2020 | 08:07 AM
JnrMazda's Avatar
Update: I have checked every AC fuse, they are all OK.
When pushing AC button, compressor does not start to spin. Magnet is not connecting compressor. Is it possible that system has been so dry that it is not starting compressor, and just needs refill ?
Old Jul 22, 2020 | 03:13 AM
cornflakes76's Avatar
If you have not already done so. Set the fan speed to 1, then push the AC button and see if it illuminates. They do have a common problem of failing to activate when the fan speed is set above 1 or 2. If you find this to be the case, the issue and fix are discussed here: Mazda Protege Fan Detection Circuit Analysis - nikosapi.org wiki
Old Jul 22, 2020 | 08:52 AM
Get the A/C gas pressure tested. If there is no gas, or low gas the compressor clutch will not engage.
rujoesmith
Sep 15, 2021 06:48 AM
tocostew
Jun 24, 2014 09:10 PM
FolsomM3
Aug 26, 2011 02:07 AM
mazdabear
Jul 6, 2011 10:24 PM
groovemaster
Sep 5, 2009 12:50 AM
