Mazda protege mp3 Swapped motor not staying running
Old Mar 8, 2024 | 05:40 PM
jaycha510@gmail.com's Avatar
Default Mazda protege mp3 Swapped motor not staying running
OK let me give you a bit of rundown. I ran low on oil so my engine started to rod knock, I and went ahead and swapped the motor.
I also swapped the crankshaft pulley. I was hearing that it had to be lined up with tooth number 20 I just switched it and it lined up with the cut out on the pulley so I left. It, I also switched the crank position sensor, I also swapped out the fuel rail and intake manifold as the engine came from Japan, and the clips were different on the harness
before I swap the manifold, I tried to start it and it did not want to turn on. Now that I swap the manifold it turns on and then turns off if I press the gas it will rev high come down to 2000 RPMs, and then cut out and less than a second
Last edited by jaycha510@gmail.com; Mar 8, 2024 at 05:42 PM. Reason: Correcting spelling
Benissemipro
Sep 27, 2021 04:47 PM
coolbeans
Mar 21, 2016 10:51 PM
eaguiar72
Feb 6, 2014 12:37 PM
jdkuebler
Jun 13, 2010 07:09 PM
dwamp2006
Aug 20, 2007 08:04 PM
