Mazda protege jumping rpm.
Old May 14, 2019 | 02:26 PM
John Snyder's Avatar
Default Mazda protege jumping rpm.
When I start my 98 protege it will idle anlil high at first then all the sudden the rpm drops and jumps and drops and jumps. I need to know where to start to get this problem fixed.
Old May 15, 2019 | 11:44 AM
depmike38's Avatar
Idle Air Control (IAC) motor. It's located right behind the throttle body and it controls the idle when you lift off the accelerator. I cleaned mine for the second time(in 220,000 miles) a few days ago. They get gunked up over time and you'll need a can of cleaner(take it off and spray it off and it'll be fine. Don't buy a new one they're a couple hundred bucks. Bad news is the IAC motor is held on with some weird spec Japanese #2 Phillips and US is slightly smaller. I changed mine out to Allen head cap screws, much easier to remove the next time. Good luck!
Old May 15, 2019 | 03:06 PM
My mechanic says it doesnt have one
Old May 16, 2019 | 08:21 AM
depmike38's Avatar
Yours is either a 1.5 or a 1.8 & they both have one. The 1.5 style is like the one on a 99-03 2.0 liter. It's held down by those 4 weird phillips screws and has a hose and an electric connector. The 1.8 has an electric connector only I believe. Either one is right at the throttle body.
Old May 16, 2019 | 08:45 AM
Ok so I took off the throttle body and found it. I can’t get it off !!!!! Fml.
Old May 16, 2019 | 10:26 AM
Ok so i took the whole throttle body off. I still can’t get them f^%*#*%#. Screes out. Even used a back out kit. Someone already tried this once. They were half stripped already. I’m so mad. Lol
Old May 16, 2019 | 02:01 PM
depmike38's Avatar
Take a sharp chisel and tap a cut for a flat screwdriver. Sometimes the tapping on the chisel even loosens the threads. I also have had luck with a small pair of needle nose channel locks. Replace them with allen head cap screws and washers. The size if it's exactly the same as my 2.0 liter is 5mm x .08 x 16mm. At least after this it's easy to do.
mattpharding
Mar 11, 2023 10:01 AM
Buck Mulligan
Jun 27, 2017 08:28 PM
wayne Sangwell
Mar 13, 2015 07:39 PM
mathos
Nov 10, 2014 12:06 PM
FBPARENT
Jul 18, 2006 09:47 PM
