Mazda 1997 Protege
Old Oct 19, 2018 | 08:07 PM
Tomcat22's Avatar
Default Mazda 1997 Protege
Hi I recently noticed that the idle on my 97 Mazda Protege was running low and the check engine light was on so I had it tested and it showed it was the idle air control valve so I replaced it and reset the computer by disconnecting the battery but right away the idle was still doing the same thing and the check engine light was back on and I had it tested again and it showed the same thing any suggestions the car has 171 thousand miles
Old Oct 20, 2018 | 06:23 AM
What was the actual Fault code?
Old Dec 26, 2018 | 12:56 PM
Tomcat22's Avatar
p0505
Old Dec 28, 2018 | 06:28 AM
Clean the MAF & throttle body. Reset computer. Start the engine & spray brake clean or water around the intake manifold and intake pipe to check for leaks.
Old Aug 30, 2021 | 09:36 PM
SteveO1976's Avatar
​​​​​​Erratic idle goes from 2200 - 1500 runs great replaced the IAC and the MAP sensor waiting for the TBS.
Any thoughts need help
notla
Dec 3, 2012 03:55 PM
323F
Feb 18, 2012 05:13 AM
mike2
Mar 18, 2011 04:18 PM
whitebear93
Sep 26, 2009 04:58 PM
jbkoenma
Aug 17, 2008 09:04 PM
