high rpm on pro 5
Old Jul 10, 2006 | 04:24 AM
afakasi's Avatar
Default high rpm on pro 5
my protege 5 has high rpm. how can i lower it?
Old Jul 11, 2006 | 06:42 PM
babyhuey's Avatar
Default RE: high rpm on pro 5
High rpm at idle? Here is the procedure for setting base idle speed on a PR5.
Warm engine to normal operating temperature and make sure all electrical loads are off (Fan, A/C, Rear defroster, headlights, etc).
You next need to ground the TEN pin in the DIAGNOSIS connector as shown in the first drawing. It is located in the left rear corner of the engine compartment by the wiper motor. Once the TEN is grounded then set the base idle speed to 700 rpm +/- 50 by turning the AAS or Air Adjust Screw on the throttle body as shown in lower pic. Screw is near where the black rubber boot connects to the throttle body and on the back side. DO NOT ADJUST THE TAS SCREW as it is preset from the factory and there is not setting procedure once it has been moved unless you want to buy a new throttle body.
[IMG]local://upfiles/1377/406685558E3B4E32BCC9E9F389BEC029.gif[/IMG]
[IMG]local://upfiles/1377/B9D930C9A5794809B89678A52979695D.gif[/IMG]
sasjzl
Jan 20, 2014 08:13 PM
Fireman27
Jan 10, 2012 02:30 PM
pharty01
Dec 6, 2011 01:44 PM
masterov
Jun 21, 2007 07:16 AM
danijel
Jun 7, 2005 02:08 AM
