P0507 Idle Control System RPM High
Old 01-04-2007, 08:11 PM
pharty01's Avatar
Default P0507 Idle Control System RPM High
2002 Protégé 5. P0507 Idle Control System RPM High. When it's cool out and I start the car the idle shoots up to 2600 RPM then drops to around 2200 RPM after a couple seconds. If I touch the gas pedal at all it shoots back up to 2600 RPM until the engine warms up, then it goes back down slowly. I also noticed that once the engine is warm and I come to a stop it takes two or three seconds for the idle to come back down.When I push the clutch in when shifting the RPM’s go up by a couple hundred. I did not initially get acheck engine light.After a couple months of this the light finally came on. I did clean out the Idle Air Control Valve a month and a half ago and it made no difference. It's a manual by the way. I hope someone has some Ideas to share on this. Thanks.
Old 11-18-2011, 01:18 PM
aftrburnrs's Avatar
Did you ever solve this problem? I am having almost the same exact problem and replacing my IAC did nothing.
Old 11-18-2011, 04:25 PM
tanprotege's Avatar
I found this on google referring to a Chevrolet:
- Dirty throttle body
- Electric throttle control actuator mis-adjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
I don't no if the 02 protege has an electric throttle control. Clean the throttle body both outside and inside. I hope it helps.
Old 11-18-2011, 04:34 PM
aftrburnrs's Avatar
I have already replaced the IAC with no improvement and will be going through that list to see if any of it will help.
Old 12-06-2011, 01:44 PM
aftrburnrs's Avatar
Turns out that my accelerator cable was not allowing my throttle to close all of the way. Its fixed now and running well.
SoupNazi
01-26-2012 08:35 PM
Fireman27
01-10-2012 02:30 PM
REDKAISER
12-20-2007 02:52 PM
rbailey644
05-17-2006 09:54 PM
Quick Reply: P0507 Idle Control System RPM High
