front wheel bearings
03 protégé 5 . shop told my daughter . need to replace passenger side wheel bearing . noise and grumble and AT light flashing . I changed the bearing and still have same noise plus pulls right . starts at 10 mph . I need to know next step what does the transaxle light mean? is there another carrier bearing up by the motor on the cv shaft ?
Need to pull the codes and post those. A pull is most times caused by a tire (belt shifted internally) You can swap the front tires and if it pulls left afterward it is a tire. If not then camber/caster needs to be checked.
mbariesheff
Aug 30, 2009 05:23 PM
