front wheel bearings
03 protégé 5 . shop told my daughter . need to replace passenger side wheel bearing . noise and grumble and AT light flashing . I changed the bearing and still have same noise plus pulls right . starts at 10 mph . I need to know next step what does the transaxle light mean? is there another carrier bearing up by the motor on the cv shaft ?
Need to pull the codes and post those. A pull is most times caused by a tire (belt shifted internally) You can swap the front tires and if it pulls left afterward it is a tire. If not then camber/caster needs to be checked.
note ,It also has the A T light flashing ,electrical trans problem . and it clunks when put into drive
Yea, There is a code in the PCM for the AT light flashing. You just can't guess on that. You will have to get the codes pulled.
It was the driver side bearing . also driver side tire was bad making it pull to the right. did a brake job while in there . 2 new front tires . And The AT light went off
