Excess noise
Old Feb 13, 2009 | 04:54 PM
ntstock93's Avatar
Default Excess noise
When I start the car with the clutch pressed the car is quiet. When I let the clutch pedal up the car gets noisy and the rpms will lower and then go back to where they were. Any ideas?
Old Feb 20, 2009 | 04:18 PM
ntstock93's Avatar
Is it possible the tranny is low on gear lube? Is there synthetic lube available and would this help the noise?
Old Feb 20, 2009 | 06:21 PM
wsoape281's Avatar
sounds like it could be a bad throw-out bearing. is it amplified when it is colder outside?
Old Feb 20, 2009 | 07:41 PM
ntstock93's Avatar
I thought it was the throw out bearing but it gets quiet when I push the clutch in.?
I may be a little louder when its cold.
Old Feb 21, 2009 | 05:26 AM
wsoape281's Avatar
i have had throw-out bearings that only made noise when i let go of the clutch while it was engaging.
Old Feb 21, 2009 | 08:29 AM
hixx's Avatar
The only bearings turning with the clutch out are the front input shaft bearing and input shaft pocket bearing. The throwout bearing should not be touching the pressure plate and the pilot bearing is 1 to 1 with the flywheel so the noise is an internal trans bearing.
Old Feb 22, 2009 | 06:38 AM
ntstock93's Avatar
If I pull the tranny can this be fixed? (I do my own repairs) or should I just take it to have it rebuilt? What does this usually cost?
I'm going to try the synthetic gear lube first.
Where are the drain/fill spots on the 5spd?
Old Jun 8, 2009 | 05:48 AM
ntstock93's Avatar
Default Update
The noise got worse last week so I pulled the tranny this weekend. The throw out bearing and the pilot bearing are very dry. The throw out bearing is noisy and spins real easy.
What is with the lower ball joints? I had a hell of a time getting them down. I took off the nut and bolt that goes front to back and it was hard getting the ball joint down.
imaco
May 1, 2013 09:23 AM
fflt765
May 25, 2012 12:52 PM
mickpdx
Jan 14, 2009 10:38 PM
jbrown
Aug 15, 2006 12:07 AM
