Driver side front issue
Old Nov 3, 2017 | 10:20 PM
Sean Tucker's Avatar
Default Driver side front issue
so last weekend I changed the drivers side front bearing, lower control arm and putter tie rod. At first I didn’t notice anything wrong but on my 45 min drive home at speeds much higher then city (50km) there was a wobble and when I used the breaks they pulsed on that side. Could the bearing have not ceated properly or could the rotor be shot? Before doing the bearing there was no wobble and no pulsing.
To to clarify I changed the same parts on the passenger side the weekend before and rode great.
Old Nov 4, 2017 | 03:18 AM
Go back & re-check everything you've done.
Old Nov 4, 2017 | 01:14 PM
I have done that a few times now. I just checked it and when I loosened off that 1 inch 1/4 centre nut there was quit a bit of play between the main hub and the other side of it. (I’m no mechanic so using lamens terms cause that’s all I know)
punkascii
Aug 10, 2009 05:34 PM
suyeda16
May 12, 2008 12:21 PM
toloquta
Dec 21, 2007 04:33 PM
sstockton
Aug 15, 2007 05:51 PM
