Cranks but no start
Old Nov 15, 2013 | 06:07 PM
trevormarsh's Avatar
Default Cranks but no start
2002 Protege DX 2.0L w/5 speed.
Cranks but no start. Good spark on all 4 cylinders. Fuel present in rail and in cylinders. New plugs. Replaced fuel pump relay (bad). Fuel pump runs as I can hear it. Knock sensor error in computer cleared. Timing belt checks good. Cleared gas from cylinders, dried plugs and no change. cranks but no attempt to start. Compression seems ok but no tester. Cam and crank sensors could cause a no start? Any suggestions?
Old Nov 15, 2013 | 07:05 PM
Kevinkpk's Avatar
Originally Posted by trevormarsh
2002 crank sensors could cause a no start? Any suggestions?
Yes, and any codes?
Old Nov 15, 2013 | 08:06 PM
Default no start
Just the knock sensor code.
Old Nov 16, 2013 | 07:51 AM
Kevinkpk's Avatar
You say it has good spark, what color is the spark?
Old Nov 16, 2013 | 08:53 AM
good spark. blue/white in color.
Old Nov 16, 2013 | 11:46 AM
Car ran fine the same day it would not start. The only problem found was the fuel pump relay. That has been replaced. Still won't start. Would a fuel rail pulsation damper cause a no start? The screw in the damper was almost falling out. Is this adjustable?
Old Nov 16, 2013 | 11:52 AM
Kevinkpk's Avatar
It could starve it, make sure you are getting proper fuel pressure to it. I question why the relay was an issue.
Old Nov 16, 2013 | 04:14 PM
checked relay and it was not working. Tested and failed. New relay and fuel pump can be heard running. I have fuel in the rail and in cyliners (verified visually) but I have no fuel pressure gage to check actual pressure. Any suggestions?
Old Nov 16, 2013 | 04:37 PM
Kevinkpk's Avatar
I still suspect fuel pressure, can you rent/loan a gauge? If the spark color is what you say, that is good. The fuel rail should have a shrader valve that you can plug a gauge into, is this pump original? Again, I question why the relay failed, not saying that they don't, but if the contacts were burned tells me an (possible) issue with the pump.
Old Nov 16, 2013 | 06:01 PM
right. No burned contacts. It just did not work. I will have to see about the fuel pressure check next.
