Broke Transmission Oil Pump
you can inspect for any unusual noises when you rotate the inner shaft, or look for signs of metal shavings in the transmission fluid. If you're unsure, it might be best to have a professional mechanic take a look before reassembling everything.
Good luck with the engine swap! You've got this.
you can inspect for any unusual noises when you rotate the inner shaft, or look for signs of metal shavings in the transmission fluid. If you're unsure, it might be best to have a professional mechanic take a look before reassembling everything.Good luck with the engine swap! You've got this.
As fr a professional "mechanic" most are not well vised or experienced in automatic transmission diagnosis when they are apart. In fact, most when there is a problem will usually start giving estimates to replace the transmission or having your rebuilt and then they install it. Main reason is there are specialized tools required.
Goatman
May 10, 2009 10:14 PM
