battery light shows charge
Old Jun 11, 2005 | 07:53 PM
barbaranna's Avatar
Default battery light shows charge
I have a 1995 protege mazda and it has worked fine until my husband tried to put the air conditioner on and then on the dash it shows a battery and it is lite up and shows charge. but my temp gauge shows right on hot and will not move. could you tell me what this might be. I thought it might be the alternator but with the gauge like that I am not sure. It is driving ok.The only thing I have noticed within the last couple of days is when it shifts it pulls back a little, just slightly and sometimes when it has been turned off it makes a metal sound but not always this just happened all today
the other problem I have is the windshield wipers. This is hard to explain.It is not where the arm is connected by the bolt with the cap where you can adjust it, it is next to it. there is a cross screw looks like under a small grill and when I move the arm it looks like it is cracked under the grill some where. when I turn the wipers on they flap off the window and stop in the middle of the window
Old Jun 11, 2005 | 08:43 PM
bdmazda's Avatar
Default RE: battery light shows charge
i would definately say that the alternator is the source of the first problem, the second with the wipers, I would say that the wiper control arm under the wiper cowl is broken, or the plastic retainer on the end of the control arm is cracked, extremely worn or missing, check those out and should find your problem.
Old Jun 11, 2005 | 11:06 PM
barbaranna's Avatar
I don't know if I am doing this correctly but if you can read this, for the wipers can it be welded together and for the alternator problem would the alternator cause my temp gauge to go to H.
Old Jun 12, 2005 | 10:41 PM
bdmazda's Avatar
the wiper control arm can not be welded because the plastic collar i referred to earlier, has to be able to pivot, and the temp gauge..........if the alternator is not working correctly, many sensors, gauges and the like will not work correctly (malfunction) if you replace the alternator and still have the temp problem, I would definately replace the thermostat next (about 3 bucks) and that way, you will eliminate yet another possibility. I hope this helps, post again for more information if you need it.
Nikolay Puradzhiev
Apr 16, 2013 12:04 PM
mtsweets
Feb 10, 2013 08:47 AM
Baston-Rob
Dec 25, 2011 04:48 PM
zilla
Dec 23, 2010 11:33 PM
Tomuc
Dec 2, 2008 08:49 PM
