96 mazda protege ignition timing advance
Old May 14, 2014 | 09:46 PM
daquane25's Avatar
Default 96 mazda protege ignition timing advance
So yesterday, I used this application and scantool called autotap on my car. I got a display of everything supported by my car and found out my ignition timing advance is off by -20 degrees. Could this be the reason why it won't start?
Old May 14, 2014 | 10:13 PM
tanprotege's Avatar
yes, this is enough to cause trouble.
I helped BengalBrad to get his MX 3 started again. First make sure your timing belt is set correctly. Use some white paint to enhance the ignition timing marks both on the harmonic balancer and on the timing cover. Then loosen the distributor bolts so you can turn the distributor by hand and turn it counter clock wise, facing the distributor cap. Now get a helper to crank the engine while you turn the distributor clockwise until the engine starts and keeps running. Now use a timing light to set the ignition timing. Check it once more when the engine is properly warmed up.
Let us know how it goes.
daquane25
Nov 11, 2014 10:01 PM
Ferret626
Oct 16, 2010 04:36 PM
hawker
May 7, 2009 01:44 AM
mazda99
Aug 13, 2008 04:18 AM
phils2200
Apr 24, 2006 10:59 PM
