92 Protege, idles w/ vibration, tune up done.
Hi all,
My wifes car is a 92 protege. Auto 1.8 SOHC with 340,000km.
The car runs really good, gets great gas mileage, and everything works on the car.
The only thing is it has a vibration to it.
It can be felt while sitting in drive. The whole car has a slight vibration to it.
This weekend Idid a tune up. Plugs, cap/rotor, wires, air filter, and added a little fuel injector cleaner in the tank.
My wife claims the vibration isn't as bad, it idles a bitsmoother, and she can tell I've done the tune up.
The car is "peppier".
About ever 3 months I jumper the little diagnostic connector and sometimes find the *blinking* fault #17.
>O2 SENSOR HAS DETECTED A RICH OR LEAN CONDITION
The Engine light is never seen while driving,....only at start up...as expected.
The fuel filter is about 2 years old. and the O2 sensor was changed 4 years ago.
Last December she had a E-test done, and the guys there say the numbers were great.....
Any ideas what I could be looking for?
I've looked around for vacuum leaks and found nothing.
I also cleaned the MAF with a MAF approved cleaner.
Thanks.
Bob
Thanks.
Bob
Where is the idle air control valve? I'm going through my mazda book...don't see that name.
Or is there another name for it?
I added some fuel injector cleaner on the weekend....I'll give that a good run through.
I have a new fuel filter. But I can't get at the bottom hose/connection.
I got the top hose off, and the filter out of it's bracket, but the bottom hose is killing me.
So I had to put it all back together.
The other thing I could try is an intake cleaner??
I've been doing some searching....motor mounts see to be an issue.
Anyone else have a vibration issuethat was solved with new motor mounts?
Also, which one(s) did you change?
Thanks,
Bob
Thanks,
Bob
blackbolt22
Sep 23, 2016 01:48 PM
brad follack
Aug 5, 2011 10:06 PM
