2003 P5 Installed FSZE, now what are my options?
Old Aug 26, 2024 | 03:10 PM
YellowP5's Avatar
Default 2003 P5 Installed FSZE, now what are my options?
I posted this in the other forum, thought I might get some answers here too.
Hello guys,
I was unaware of the differences between the engines so I installed a JDM motor with all the fittings swapped from the original engine.
I have a pinging problem.
Every sensor and coil has been changed. So what are my options at this point?
1. Is this pinging going to kill the engine?
2. All I want is to run the engine without pinging. I do not care for any extra power.
3. I also want it to run at 87 octane.
What are my options now?
Old Aug 26, 2024 | 05:05 PM
MeB2000's Avatar
Does the engine ping with 95 octane fuel? Was the ECM swapped as well?
Old Aug 26, 2024 | 06:58 PM
YellowP5's Avatar
I have not tried it because I do not want to run anything other than 87.
It has the stock ECU.
It is Automatic Trans.
Old Aug 26, 2024 | 08:19 PM
MeB2000's Avatar
Do you know what the compression ratio is for both engines? Could the JDM engine have more advertised compression? If so, you would definitely need the ECM that controlled the JDM engine......not the stock one.
Old Aug 26, 2024 | 08:43 PM
YellowP5's Avatar
You can't.
The FSZE engine is OBD-1. It has a different ECU and everything else like manifolds and the crank pulley are different.
Old Nov 7, 2024 | 12:24 PM
YellowP5's Avatar
I did use the long type spark plugs and it made a lot of difference. However, it was never perfect. I ended up selling it and bought an RB Hyundai Accent. Much better gas mileage, similar power and a lot newer.
Thank you guys for all your help.
angelus2511
Sep 20, 2021 07:18 AM
thymebreaker
Oct 24, 2019 10:53 AM
VELOCITY_RX7
Jun 18, 2010 01:55 PM
SpicyMSP
May 12, 2009 01:15 PM
GANUSCH
Jul 9, 2008 05:15 AM
