2001 Protege 323 - Rough idle after crank
Old Mar 15, 2023 | 12:46 AM
Nazzie's Avatar
Post 2001 Protege 323 - Rough idle after crank
G'day all,
First post here
Needing some help with my Mazda Protege 323 2001 which has an issue with almost immediately dying on a cold start. I almost have to floor the accelerator after a few cranks in order to get the engine somewhat idling. The issue gets slightly better as the engine warms up but still with a rough idle until driven about 5 mins and then seems to idle around the 1250 - 1300rpm mark. Sometimes after a 15-20 min drive the car will struggle to start too. But eventually does after a few tries.
I MUST mention that the rough idle happens towards the lower end between 500-200rpm and the car shudders and dies. I crank again and this repeats a few times before the car warms up and then I'm sorta good to drive her.
What I've done so far:
* Cleaned the MAF sensor with Mass Airflow cleaner (But forgot to check for buildup along the intake hosing of the sensor)
* Sprayed Carb cleaner into the intake for the IAC
* Tried to adjust the idle timing - thinking a higher idle might help but it didn't
* Replaced spark plugs & about to replace the ignition coils too
*Tried looking for a vaccum leak but unable to find anything (Using my ear to a hose with a funnel at the other end)
Would be great if I can get anyone to please help! Will updat if I have missed anything else.
Cheers
Jake
Old Aug 24, 2023 | 08:38 PM
johnsunruh's Avatar
Default Update requested
Is your idle fixed?
Old Aug 24, 2023 | 09:14 PM
Nazzie's Avatar
Originally Posted by johnsunruh
Is your idle fixed?
Nope, still idling rough until warmed up. Cold morning starts are the worst. I often get blue smoke at startup, followed by white smoke. Then I'm good to go.
Old Dec 7, 2023 | 12:24 PM
VictoriaFergusonn's Avatar
Is your idle fixed?
Old Dec 7, 2023 | 01:11 PM
The blue smoke is telling you time to check the compression both dry and wet and do a cylinder leak down test.
White smoke if it dissipates in the air is normal but if it is true smoke then the above ^^^^^^^^^.
sslavik
Oct 11, 2017 09:34 AM
Orientpete
Dec 31, 2011 05:04 AM
motor_voter
Jan 23, 2009 10:34 PM
jasonlife
Jan 4, 2007 09:23 PM
