2000 Mazda Protege DX - Not shifting smoothly, battery light comes on at 40mph
Old Feb 20, 2023 | 08:09 AM
Blader's Avatar
That stuff in fuse blaock looks like corosion or a short from circuit or water leak on it.. See what those fuses feed and yes obviously clean it. Silicone grease doesnt corrode. But as far as the rest just as I had said check all grounds. They will wreak havoc on the system as u saw. As far as alternators as I had also said previously that ones from stores or online are horrible quality and dont last, when mine went I had only changed bearings, as voltage reg either works or it doesnt and if theres enough length on brushes dont change them ,and as long as slip rings are good then your good to go. Anyhow glad you found it Good Luck
Old Mar 22, 2023 | 01:27 AM
ic101's Avatar
I have a long term update on this issue. After cleaning grounds the alternator has behaved well, but ended up with intermittent OD Off light and limp home shifting.
I was able to pull the transmission code using FORScan and a cheapish dongle that they recommend.
The odd shifting issue ended up being the EPC solenoid in the transmission. Probably related to the electrical failure. This video is for a Mazda 6 but the troubleshooting I ended up doing is the same at the transmission:
dsteh
Oct 13, 2021 11:39 AM
Manganda
Feb 10, 2021 02:30 PM
Traviswgl
Jan 19, 2019 04:24 PM
jttraverse
Aug 25, 2016 03:31 AM
Abisnail
Aug 11, 2009 02:34 AM
