1996 DX Protege engine lacks power and misses
Old Apr 11, 2010 | 02:56 PM
ScottK's Avatar
Default 1996 DX Protege engine lacks power and misses
Hi All,
Thanks for any help you can give me. I am a newbie here trying to figure out why my Mazda DX with 1.5 liter 4 cylinder and the engine is stumbling and lacking power. It seems like a cylinder is missing.
The check engine light diagnostic shows code P0303 or misfire on cylinder 3.
I have checked spark by taking out the plugs and test them one by one by pulling each one and placing back in the wire and spin the engine over next to a grounded part of the engine. The spark looked like yellow/orange.
I also swapped #3 and #1 injectors and have the same results.
What would be next as far as troubleshooting?
How do I further troubleshoot the ignition coil?
Thanks!
Scott
Old Apr 16, 2010 | 07:23 PM
darkstar4100's Avatar
my car did that and it was the ignition coil you can olm the plug parts of the coil when you do it you should come up with the same numbers when your cranking it, when i did it one was good seemed okay the other was wayyy off
Old Apr 21, 2010 | 09:49 PM
ScottK's Avatar
thanks but I checked and there is a strong spark. It even jumps through the insulation to ground when I pull the boot but I will check what you said. How do I ohm it out?
joshsopczak
Oct 1, 2013 04:05 PM
daquane25
Apr 14, 2012 04:51 PM
revan
Apr 30, 2010 04:59 PM
mindbender44
Apr 16, 2008 01:39 PM
kosmos
Jul 26, 2005 01:10 AM
