1995 No air flow....but blower motor & fuse work
Old Sep 14, 2011 | 01:31 PM
Flinticus's Avatar
Question 1995 No air flow....but blower motor & fuse work
I have a 1995 Protege stick shift w/ 164k mi everything works fine, except for this problem. (There are no lights on the dash of any kind aka the car runs great, ****s perfectly, and everything else works great.) I have no air flow...PERIOD...the blower motor has continuity (so no blown fuse), and the main fuse in the fuse panel is not blown. I pulled out the HVAC control unit out, and everything looks to be connected properly (as far as I could tell). WHAT ON EARTH COULD THIS BE?! Anyone have an idea?
Old Sep 16, 2011 | 02:07 PM
tanprotege's Avatar
If I understand you right, the blower motor runs.
I would check if I get airflow with the A/C on Max. If yes, it recirculates but it doesn't let in fresh air in other settings.
Stuck baffle?
Control cables incorrectly set?
Fresh air intake at the cowl cover obstructed?
Obstruction in the duct work?
Fan separated from the motor? I. e. motor runs but fan stands still.
Old Sep 18, 2011 | 03:42 PM
Flinticus's Avatar
Thank you for some great ideas tanprotege
Yes, the blower motor runs, and I will definitely work on checking out your suggestions. I definitely have my fingers crossed that one of those things may be the issue.....
Thanks again...
Gabby1234
Aug 1, 2021 09:03 AM
lockwoodm
Aug 12, 2009 01:38 AM
wrecks74
Jan 18, 2007 02:45 AM
Mazdaboy2600i
Feb 14, 2006 01:02 AM
ryantatum20
Aug 16, 2005 03:33 AM
