1995 No air flow....but blower motor & fuse work
I have a 1995 Protege stick shift w/ 164k mi everything works fine, except for this problem. (There are no lights on the dash of any kind aka the car runs great, ****s perfectly, and everything else works great.) I have no air flow...PERIOD...the blower motor has continuity (so no blown fuse), and the main fuse in the fuse panel is not blown. I pulled out the HVAC control unit out, and everything looks to be connected properly (as far as I could tell). WHAT ON EARTH COULD THIS BE?! Anyone have an idea?
If I understand you right, the blower motor runs.
I would check if I get airflow with the A/C on Max. If yes, it recirculates but it doesn't let in fresh air in other settings. Stuck baffle? Control cables incorrectly set? Fresh air intake at the cowl cover obstructed? Obstruction in the duct work? Fan separated from the motor? I. e. motor runs but fan stands still. |
Thank you for some great ideas tanprotege :)
Yes, the blower motor runs, and I will definitely work on checking out your suggestions. I definitely have my fingers crossed that one of those things may be the issue..... Thanks again... :) |
