1994 Protege!!!! i Need some Answ. pls:!!!
Old Oct 5, 2009 | 01:20 AM
pinoy-db1's Avatar
Default 1994 Protege!!!! i Need some Answ. pls:!!!
we'l i have a 94 protege and i dont really know anything about mazda so yea!!!
my question is why does my car shake everytime i be steppin on my brake???
how is it when my car is on a full stop my car seems to be having a hard time getting power and sometimes when im coming to a full stop my car will jus die once i let go the brake????
Old Oct 16, 2009 | 07:32 PM
copierman's Avatar
the brake problem - check the front brakes, drum brake or disc ??? if drum brake , the drummaybe need replacing( machining old one just as costly) if disc brakes , the rotors may need replacing. Have certified mechanic check brakes if DIY skills rusty.
idling problem - replace plug and wires to start with , see if that helps stalling problem
Old Oct 23, 2009 | 02:38 AM
darkstar4100's Avatar
are you an automatic or a standard, the shaking i think is warped brake rotor's really the mazda doesn't have alot of power to begin with but if it seems like it should have more you should take your car in for a full tune up (timeing belt, spark plugs and wires,oil change, filtre change) everything
Old Oct 26, 2009 | 09:37 PM
tye's Avatar
tye
possibly check your vac hoses too.. kinda sounds like my problem. always check your engine fluids old engines wear and tear.
badassgurl1030
Aug 8, 2007 09:54 AM
ketl.14
Jul 19, 2007 12:31 AM
badassgurl1030
Jun 30, 2007 10:01 PM
choxxx
Feb 7, 2007 01:03 PM
choxxx
Feb 5, 2007 12:36 PM
