is it possible to have turbo on carb?
is it possible to have a turbo added on a carbeurator engine? 91 b2200, i want to keep it a 4 cylinder but i want to put a turbo on it if it is possible.
What do i need to have it work?
What modifications has to be done?
RE: is it possible to have turbo on carb?
Simple answer... Yes
More in depth... check out www.turbomustangs.comas there's a wealth of knowledge there and will help you set up a blow through carb application for your goals.
turbochargers have been around a lot longer than fuel injection.....You'll need a good high-flow carb. My personal preference are Pro Systems carbs....a little pricey, but well worth the money.
You can make alot of horsepower on a home-built carb. There's no need for a $700 carb when you're only shooting for 300-400 horsepower. You can get a 600dp, rebuild it and modify it for NO MORE than $300.
Willie2124
06-17-2009 11:29 PM
blasphemous
02-28-2007 03:02 AM
