B4000 pickup
Old 04-11-2012, 10:39 AM
edlan's Avatar
Default B4000 pickup
this morning, after leaving dentist, truck would not start. Dash lights were on, radio on but nothing from the starter. After fooling with the shifter, (automatic) it started fine. Got home, same thing but could not make it start. Any ideas? Is there a switch for the shifter?
Old 04-28-2015, 02:20 PM
jboorman's Avatar
it may be the passive antitheft system.
Old 04-30-2015, 08:06 AM
Cusser's Avatar
Automatics have a neutral safety switch which "closes the circuit" to allow cranking when the shifter is in park or neutral. That should be checked since fiddling with the shifter allowed it to start once, or possibly the shifter linkage needs a little adjustment.
Another possibility is that moving the shifter was coincidence and that the ignition switch is making intermittent contact to the starter.
Of course, Mr. Battery needs to be checked UNDER LOAD; just because radio or lights come on mean nothing.
Question: do lights dim when you try to start it (should, unless the electrical circuit is not being completed) ? Better test is voltmeter across the battery terminals while trying to start, and post that voltage.
MTMazda
02-03-2007 01:45 AM
EDE1981
06-27-2006 01:30 PM
bhc6
03-04-2006 10:59 PM
poorboy_616
02-22-2006 02:36 AM
Bill Hicks
12-20-2005 12:38 AM
Quick Reply: B4000 pickup
