1990 B2200
Old 05-28-2008, 07:51 PM
bully122's Avatar
Default 1990 B2200
I just bought a 1990 B2200. The truck only has 65,000 miles on it. The problem is it sat up for about 10 years. I had to replace the fuel tank and lines, clutch master and slavecylinder, and some other minor things. The problem that I am having is with the carb. I installed a rebuild kit in it and it runs okay but seems to run a little rich. I have adjusted it some but can't seem to stop all the black smoke. Also Iwould like to know about the plate under the carb and were the wire is suppose to be connected. Thanks for the help.
Old 05-29-2008, 09:29 PM
Default RE: 1990 B2200
the plate under the carb is a heater...and to me it sounds like your choke is stuck
Old 05-31-2008, 06:55 AM
bully122's Avatar
I checked the choke and it is not stuck. After I found the connections for the plate and choke wires the engine seems to run better. Doesn't seem to be any smoke at idle now. Thanks for the reply.
Old 05-31-2008, 07:24 AM
Good Job, bully122!! And welcome to the forum too.
(I hope that's only your screename and not a reality?)
barako927
04-09-2007 04:27 PM
Jodys1990SE5Mazda
02-08-2007 01:26 PM
Singing Preacher
12-28-2006 07:55 PM
Singing Preacher
08-15-2006 08:29 PM
rhino1
11-13-2005 01:50 PM
Quick Reply: 1990 B2200
