Mx3 does not start after washing engine bay - crank slowly
Hi
I have bought a Mazda MX3, the guy that I have bought it from has washed the engine bay with a pressure washer :? and after that the car coud not start.
He has also taken the radio out. Is there a anti theft system who disable the start of the car when it has been out of power? If it is how do I reset?
The symptom is:
When I turn the key the engine cranks slowly, it seems that is missing battery power. I have checked that there is power at the battery 12,5V and tried with another battery and jumper cable but still the same, it crank slowly.
Also when I turn the key the light in dashboard goes out.
Does any have an idea of what who can cause the problem?
Regards
Per
The symptom is:
Regards
Per
Hi
I have now get the car to crank normal, but I got a new problem.
The reason for the slow crank where that the previous owner had installed a alarm, bullgard 950s
When I removed the alarm, the car cranks at normal speed-but it still does not start.
A new problem, when I turn the key - all the lights at the dash lights up, but not the engine light.
As I remember before I removed the alarm there where light in check engine when I turn the key, and it turned of after 3 sec.
Now there are no light in check engine.
I am pretty sure that I have soldiered the wires together where I removed the alarm from, only one wire where cut at the starter key (the black/blue one) and a black one where taped into.
I have checked the fuses in engine bay, and also at the driver leg. All checks fine.
A note when I turn the key there are also no beep tone for seat belt and key in ignition - before that I removed the alarm there where also no check sound
What coud the problem be... I think that the no start issue is due to the missing check engine light
