Couple of quick questions....
Old Nov 27, 2013 | 08:37 AM
mprtftr's Avatar
Default Couple of quick questions....
I recently changed the fuel pump in my '93 MX6 and before I did so, the fuel gauge worked. When I installed the new pump, i soldered the new power and ground wires and used heat shrink to seal them up. I didn't mess with the other wire on the assembly. Has anyone else had this problem and if so, what did you have to do to correct it? I really don't want to have to drop the tank again unless I really need to do so. Also, if anyone has an extra NGK #2 plug wire in good shape laying around (for V6) how much would you want for it shipped to 23805? The tip on my #2 plug wire somehow or another broke and I'd like to not have to order another complete set of wires for just one wire. Thanks in advance!!
Old Nov 27, 2013 | 02:24 PM
Kevinkpk's Avatar
I assume you have correct polarity. Tie the unused wire too a good ground.
Old Nov 29, 2013 | 12:35 PM
mprtftr's Avatar
I have an intact #2 wire on there now... I just need an NGK #2 wire to complete the set.
Are there any compatible fuel sending units that anyone can think of? I really need to be able to know how much gas there is in my tank.
knucklehead11
Jan 10, 2011 05:47 AM
unclebenny
Sep 12, 2007 12:25 PM
kam1996
Jan 6, 2007 04:34 AM
TrendySob
Oct 12, 2006 11:29 PM
defaced
Sep 5, 2006 10:16 PM
