Replacing Bank 2 Sensor 1 oxygen sensor
Hi all-
New to the forum. I have a 2005 MPV that is throwing a P0154 and P2197. I'm looking to replace the O2 sensor. What is the best way to approach this problem? It looks to me to do the following:
1. Remove the radiator hose just above the sensor.
2. The sensor is just below. Remove and replace the sensor.
My question is this: what is the best tool to use to remove the sensor? It looks to be too tight to fit an o2 socket plus ratchet. I was thinking something like one of these. Thanks.
Amazon.com: VCT O2 Oxygen Sensor Flexible Double Sided Head Wrench Removes & Installs Auto Tools : Automotive
Amazon.com: TEKTON 22 mm Long Fixed/Flex Head 12-Point Ratcheting Box End Wrench | WRB35422 : Everything Else
no experience with o2 sensor replacement on that vehicle...i own 2 different style sockets for o2 sensors...typically just use a bunch of socket extensions and whichever one of these sockets will work best for the car...good luck
https://a.co/d/2a7e9Et
https://a.co/d/c5m6kyV
The tool you are looking at works very well for tight area O2 removals. If you are sure that the sensor is the issue then you don't have to worry about damaging the wires attached to the sensor. Just make sure you disconnect the harness.
The tool you are showing to use is actually safer than the conventional socket style that both DIY and mechanics often times dame the HO2 & O2 sensor both removing and replacing.
I should mention that your DTC are not definitively towards a bad sensor and may be small exhaust leaks or both sensor and leaks so keep that in mind.
Many HO2 and O2 sensors come with anti seize on the threads . They learned a long time ago how many without it get cross threaded when installing them.
I have all 3 mentioned and a few more sensors tools but the Amazon type over all works the best for me in most cases.
My first O2 sensor. Should have known they would have anti-seize on them from the factory. Thanks much.
One last thing about O2 sensors and rock auto. Don’t buy the no name or brand that is uncommonly known. You get what you pay for in quality when it comes to HO2 and O2 sensors. Pay a little more for the quality known brands .
Went with Denso....figured it would be quality. I totally agree with your sentiment on parts.
Funny thing I am not really a Mazda guy I just own one and love it. Its a daily driver with upgrades. Lol
