P1345 Crank Angle Sensor -- Intermittent Hard Starting
Old Feb 22, 2012 | 12:52 AM
hitechseeker's Avatar
Default P1345 Crank Angle Sensor -- Intermittent Hard Starting
I have a CEL with engine code P1345. When I tried to start the van today it hesitated as if battery was dying, but then it started fine. I read that perhaps the Crank Angle Sensor is faulty ? On another car ( E320 ) starting hesitation after the car has warmed up is a sure sign of a bad Crank Position Sensor. I get the problem when the van is not warmed up. Three questions:
1. Does this problem sounds like a Crank Angle Sensor gone bad ?
2. On an MPV MY 1996, where would I find the Crank Angle Sensor and is it hard to replace.
3. Is there something else I should do to make sure its a Crank sensor issue?
4. What other issues can cause this kind of a problem ?
TIA for your help.
Old Feb 22, 2012 | 09:20 AM
READ THIS: http://repairpal.com/mazda/mpv
Old Feb 22, 2012 | 12:15 PM
Mazmart Trini's Avatar
It is a Cam Pos Sensor Fault code.
Old Feb 22, 2012 | 09:59 PM
Thanks for the comprehensive answer. I will use this as a basis of diagnosing and fixing the problem. The issue is intermittent but its accompanied by almost a failure to start -- almost like the battery is dead.
Old Mar 5, 2012 | 12:38 AM
Default Location of the CMP sensor on 1996 MPV
Does anybody have a pictorial DIY on changing the CMP ? Is the CMP behind the passenger wheel ?
I think the battery is OK, but not sure. Should I just change the battery and see if the problem goes away ? The OBD II info says that its the CMP sensor.
Old Aug 17, 2015 | 11:30 AM
This is an old thread. I realize that I have learnt a lot since posting my question !
Is there an easy way to tell if the P1345 is really caused by the CPS ? In other words can the output of the CPS sensor be verified through the connector wiring ?
( I have the same problem again on this vehicle )
EarlyCuyler@Glug
Feb 14, 2015 04:40 PM
cornwellbs
May 15, 2011 01:17 AM
fairlaniac
Feb 5, 2011 02:01 PM
PneumaticTire
Dec 26, 2007 10:31 PM
02protege
Aug 25, 2007 04:43 PM
