misfire on #1
Old Aug 1, 2007 | 09:01 PM
debobis8's Avatar
Default misfire on #1
i have a 2005 mpv .i took it to the dealer they put it on the computer .results showed misfire on #1. i need to change the coil .which one is #1. with my luck it is the hardest one to get to.
Old Aug 4, 2007 | 02:16 PM
Armor3dOrange's Avatar
Default RE: misfire on #1
Isnt it still under warranty?
Old Aug 4, 2007 | 04:26 PM
debobis8's Avatar
no it has 75000 miles
Old Oct 13, 2007 | 08:24 PM
mikespecht's Avatar
the firing order for a 2004 mpv isfront pass side #4, rear pass side is #1, front mid #5, rear mid #2, driver side front #6, driver side rear #3. they should be the same. i had to replace a spark plug on #5 for a friend. it is located under the black cap(individual coil) make sure you have a long extension and a spark plug socket, or you will never get it out. If you have an auto-zone close they will print you off the firing order, and about any other information that would be in a repair manual for free, so dont buy one.
Old Oct 13, 2007 | 08:46 PM
mikespecht's Avatar
what i said was not the firing order it was the the cylinder numbers. the actual order is 1-4-2-5-3-6, but he placement of the cylinders is as i stated before.
abhaslaj
Oct 6, 2020 11:12 PM
Brian_7
Dec 6, 2011 04:25 PM
CardsFan420
Nov 8, 2006 06:25 PM
KuroRyu256
Jun 23, 2006 10:50 PM
JJ
Apr 30, 2005 10:39 PM
