misfire on #1
i have a 2005 mpv .i took it to the dealer they put it on the computer .results showed misfire on #1. i need to change the coil .which one is #1. with my luck it is the hardest one to get to.
RE: misfire on #1
Isnt it still under warranty?
RE: misfire on #1
no it has 75000 miles
RE: misfire on #1
the firing order for a 2004 mpv isfront pass side #4, rear pass side is #1, front mid #5, rear mid #2, driver side front #6, driver side rear #3. they should be the same. i had to replace a spark plug on #5 for a friend. it is located under the black cap(individual coil) make sure you have a long extension and a spark plug socket, or you will never get it out. If you have an auto-zone close they will print you off the firing order, and about any other information that would be in a repair manual for free, so dont buy one.
RE: misfire on #1
what i said was not the firing order it was the the cylinder numbers. the actual order is 1-4-2-5-3-6, but he placement of the cylinders is as i stated before.
