How to access evaporator / drain area for cleaning?
Old May 13, 2021 | 01:19 PM
jmac404's Avatar
Default How to access evaporator / drain area for cleaning?
The evap drain is clogged - very difficult to access from the engine bay, no way to really even remove the hose. I'm sure the evap area in the dash is full of pine straw and whatever else. I can't figure out any way to access this... On most vehicles you can remove the blower fan, but on the mpv the fan is nowhere near that evaporator coil.
Any thoughts? I've got the drain flowing now after shop vac'ing the tube, but I'm positive that the housing is full is debris
Old May 13, 2021 | 02:02 PM
jmac404's Avatar
Update - I was able to remove the ductwork between the blower fan and evap coil on the passenger side. This gave access to the evap box which has a bunch of deteriorated foam in it. I assume this is what's blocking the drain. I see of zero ways to access the drivers side. I used some evap coil cleaner (includes a long tube) to blast through the drain hose. I suspect this is going to have to be done a couple times a year since the foam is still loose on the drivers side of the evap box. Worst case I can cut an "access hole" in the drivers side of the box and seal with aluminum duct tape.
Old May 15, 2023 | 03:17 AM
jeyzou's Avatar
Hi, I want to clean up my evaporator on my Mazda MPV/8, perhaps you can share a picture to the ductwork location that you referring to? Thank You
Old May 15, 2023 | 04:00 PM
jmac404's Avatar
Hello jeyzou. I ended up selling the mpv, and I can't remember how I ended up accessing the drivers side. I vaguely recall that I was in fact able to access it - I don't know if I cut an access hole or what. But I specifically remember the passenger side of that coil was absolutely caked with debris.
Old May 15, 2023 | 08:11 PM
jeyzou's Avatar
Thanks for the info, I'll have a look around the driver side then ya.
Danielle123
Jan 21, 2020 04:22 AM
Rodz72ss
May 11, 2018 10:27 PM
eleebid
Oct 13, 2010 05:15 PM
lgesaguaro
Mar 14, 2007 11:28 PM
Marjnal
Aug 29, 2006 06:46 PM
