Blower motor removal help needed (2000)
Old Mar 16, 2022 | 01:56 PM
uncleflip's Avatar
Default Blower motor removal help needed (2000)
I'll start by saying I owe a beer or five to whomever can get me through this one.
I inherited a 2000 MPV, which apparently hadn't had the cabin air filter replaced....perhaps ever. It had enough debris (leaves, twigs, etc.) above the filter to make a few birds' nests. In removal, some debris fell down into the area that holds the blower motor. Running the blower now results in a loud buzzing, and I can hear something banging about in there when I start the blower.
I set out today to remove the blower motor to clean it out, and I found it impossible- simply because of the screw that's behind it (toward the front of the van). I took quite some time to find a tool that could even get into that small space- but I can't see what I'm doing, and sticking my fingers back there to guide the tool effectively blocks me from getting it in there.
My next thought would require a tool I do not have- but could easily acquire. I thought about simply removing the entire duct section into which the motor is bolted. I'd like someone to confirm it is, indeed, held in the way it looks. It appears I need to remove two screws on the back (relative to the van, visible with the glove box removed)-then one between the housing and the passenger side footwell wall. After that, it appears all that's left is a plastic trim screw on the driver-side end of the housing.
Am I anywhere close to reality on this?
Thnaks much!
Be well
-UF
Markerhead
Apr 10, 2018 12:03 PM
peterc4
May 8, 2014 11:25 AM
wrecks74
Jan 18, 2007 02:45 AM
Mazdaboy2600i
Feb 14, 2006 01:02 AM
ryantatum20
Aug 16, 2005 03:33 AM
