97 MPV will not start!
Old Aug 8, 2007 | 12:16 PM
bluntmanmazda's Avatar
Default RE: 97 MPV will not start!
advance auto????? auto zone!
Old Oct 27, 2010 | 08:31 PM
domidemon's Avatar
Default 98 MPV wont turn over
So I was driving down the highway after changing my alternator belt which was breaking and my van just shut off
Since then I have changed the distributor and the crank sensor and still no spark.
I also checked the fuel pump and its not pumping fuel to the engine but the pump is good.
what could it be? I am 400 in the hole and she still wont turn over
the timing belt is good btw
Old Nov 19, 2015 | 03:20 PM
djshotokan's Avatar
@domidemon Hey, this is an old thread, but wondering what turned out to be the issue...im having the EXACT same problem and cannot figure it out
Old Nov 20, 2015 | 10:13 AM
Anyone check/replace the fuel pump relay, and/or fuse?
Old Nov 20, 2015 | 10:43 AM
djshotokan's Avatar
Virgin1, Hey, yeah as far as components go, just about everything is new, and from mazda. fuel pump, fuel filter relays, head gaskets, timing belt kit, intake and valve cover gaskets water pump. it turns but will not start. The distributor has been rebuilt at the ignition coil and new plugs wires cap and rotor. timing is set perfect and it has one STRONG spark...found out the old fashioned way. it used to actually run with starting fluid until it ran out, but now it doesnt even run with that. Ive been reading my schematics, I do remember that if my ect was unplugged, the truck would NOT start over until i plugged it in. ive been testing wires with a powered probe and one of the wires is pink and black coming from the two prong pigtail connector on the distributor and Im not getting a positive or negative response at all. This wire, according to the schematic, leads straight to the ecm. I checked the ECM, its registering find at the OBD2 scanner. ive seen a few other wires with low or no connection however, with the so start condition, im looking at this distributor wire. I however am absolutely open to all suggestions, feed back and history with the same problem. Thanks!
Jessab
Jan 1, 2016 06:19 PM
Pochi09
Aug 3, 2010 05:11 PM
Just Me
Jun 11, 2010 11:15 PM
IslandMighty
May 5, 2010 03:55 PM
rcsimmons44
Feb 3, 2010 04:29 PM
