2002 MPV #6 misfire
Old Jan 6, 2009 | 10:42 PM
hixx's Avatar
Default RE: 2002 MPV #6 misfire
It is most likely a clogged EGR port on that cylinder. Instead of one big EGR intake port they have gone to 6 small ports. One for each cylinder. If one clogs the PCM interprets it as a misfire. It is pretty easy to fix, remove the upper plenum and clean each port with carb spray.
Old Jan 8, 2009 | 04:58 PM
Chickenman's Avatar
Update: I'm pleased, but a little embarrassed to say it appears it was in fact the PCV hose. This was forum member MJP68's first suggestion. With all the plumbing under the hood I mistook it for another hose. I should really spend the money and invest in a repair manual! The public library version was 1997. The PCV hose was collapsed where it enters the manifold and it had a noticeable leak when I touched it (hissing). The rough idling is now gone so I'm keeping my fingers crossed. I tried to take advantage of the PCV hose recall in 2004, but unbenounced to me it was replaced in 05 during other service. Since it was replaced in 05 I'm wondering if I might have done something to cause the hose to break while replacing the plugs on the rear bank 4 months ago. mox nix.
Side note: Called Mazda Parts and was quoted $28 for the hose. When I went to pick it up they said it was $68. They said the $28 hose is the old recall one. Why they are selling the old recalled hose is a mystery, and why the new hose istriple the cost is also a puzzle.
Thank you all.
canuck42
Aug 8, 2011 05:40 AM
kimle
Dec 29, 2009 08:07 PM
Hatch Kaspar
Jul 21, 2009 11:46 AM
01MPV
May 17, 2007 01:44 PM
CardsFan420
Nov 8, 2006 06:25 PM
