2000 Mazda MPV heater problem
Old Sep 23, 2013 | 08:44 PM
thelordparadox's Avatar
Default 2000 Mazda MPV heater problem
I wonder if any 2000 MPV owner has this heater problem.
Even with the heater control on high, there is barely any heat coming out of the air vents. In fact, the center vent on the dashboard blows out cold air.
- Blower fans (front and rear) working perfectly.
- The coolant circulation is working perfectly.
- No radiator leaks.
- No blown fuse.
Any suggestion and help is really appreciated. Thanks
Old Sep 23, 2013 | 09:33 PM
tanprotege's Avatar
There may be a problem with the blend door. The blend door is responsible for mixing fresh or cooled air with the heated air to achieve the selected temperature (and or dryness when you select defrost).
In some cars the actuator fails and in others the door itself fails.MPVClub.com :: Mazda MPV TSB details
Old Sep 24, 2013 | 06:04 PM
Thanks for the info. I wonder if you know of any DIY steps to replace the blend door actuator?
Thanks
Old Sep 24, 2013 | 08:13 PM
tanprotege's Avatar
Sorry, I don't have instructions. Try google searches, that's how I found instructions for the ford Windstar.
Old Sep 26, 2013 | 06:02 PM
Are there separate blend door actuators for the front and rear heaters?
Where are they located?
I can find no references about this online. Not even a single diagram. Does anyone here knows?
Old Sep 26, 2013 | 08:32 PM
tanprotege's Avatar
they call it airflow mode door and air mix door , 15 and 16 on the diagram.
http://www.justanswer.com/car/2qrw2-...-does-not.html
Old Sep 26, 2013 | 10:01 PM
Thanks. But it only shows the airflow mode door and air mix door. The culprit here is the actuator motor that controls the doors as mentioned in this service manual: http://am.mazdaserviceinfo.com/emazd...334-10-99C.pdf which I've just found. But the location of the motor is not indicated.
Old Sep 27, 2013 | 09:38 AM
tanprotege's Avatar
Apparently they are vacuum motors. It makes only sense for them to be attached to 6 and 7 in the diagram of my previous reply.
When I turn the heat on the drivers side only kicks out cold - Fixya
Old Apr 9, 2015 | 07:44 PM
deak's Avatar
I thought it was the blend door on my 04 Jeep Wrangler and replaced the part. Turns out I had a clog in my heater core. My fix was to disconnect at the thermostat. Took a hose and flushed it out. Heat is great now.
On my 04 MPV, everything works fine with NO heat. Leaking radiator fluid, found the leak near spare tire under the van. Expensive item to replace so I've been adding fluid when low, this is a short term fix that resolves heat issue. I check weekly but eventually I know my days are numbered...
Old Feb 3, 2019 | 08:54 AM
heri54's Avatar
Thumbs up
- No blown fuse.
yep, i had the same problem i changed d the air flap control actuator motor and it was the solution. how ever i could not find any place to sell em the part new one. so what i did was to opened it very carefully and cleaned it it by the inside it worked fine about two days, so, i have to get a new one if you are lucky and find it out new tell me where please. also it is located behind the glove box . it has 4 little screws and it is ttached to the blower motor case
it hs some numbers -063700- 6351 heriberto19646@gmail.com
2000-mazda-protege
Feb 26, 2013 06:20 AM
miketown
Jan 8, 2011 11:08 PM
gonzoguy
Aug 31, 2009 09:39 PM
jarrison
Mar 21, 2009 08:14 PM
