Water leak when it rains, under pass. seat
RE: water leak pools under passenger seat - 12/29/2006 12:59:54 PM
showPicture("12/29/2006 12:59:54 PM",0,0,0,638,9)
Richard
titleAndStar(6,0,0,false,",")
New Member
[align=center][/align]
Status: online
My 97 Millenia has the same problem, it is like water is running down insidethe B pillar and flooding under the passenger seat and rear seat carpet, same side. Only when it rains. Anybody have ideas? Thank's to all,
Richard. [align=right]
[/align]
i would suspect the door membrane. if anyone has removed the door panel, and not properly replaced the membrane, it will leak. stereo speakers, window lifters, if any of those have been replaced, they did a sloppy job.
I will check that, I should have also mentioned thatI getwater on the right side of the passenger seat, about 3 inches from the right side. I thought it might be coming in from the bolts that hold the grab handle I popped up the plastic trim on the roof and sprayed plastic conformal coating (several coats) that we use in the avionics to keep moisture from getting to circuit boards and components. It looks like It is coming from the sun roof, do the drain holes and tubing run down the B pillar and how would I unclog them? Happy New Year to All
Richard.
Richard.
