Trunk Problem
Old Oct 21, 2006 | 12:07 PM
MazdaSilva's Avatar
Default Trunk Problem
This is a 2002 Mazda Millenia 2.5
When I try to open my trunk by pressing the button on the door it won't open. The only way I can open it is by using the remote control or by using the key. The fuel door button next to the trunk button works.
So does anyone know why the trunk button doesn't work and how can i fix it?
Old Nov 3, 2006 | 12:27 AM
mrussum's Avatar
Default RE: Trunk Problem
It's the trunk lock actuator located on the trunk latch in the trunk ofcourse.
Call a local salvage yard. Check your dealer for there price first so you'll know if your getting a good deal.
A good used price for this item shouldnt be anymore than $30.00.
Be sure it works before leaving the salvage yard, ask if you can plug it into your car first.
Old Nov 3, 2006 | 10:49 PM
keninn's Avatar
i dont think so. if the actuator was bad, then the remote would not open the trunk. the remote has to trip the actuator, and it is. i would suspect the switch itself, or possibly a broken wire coming off the switch. diagnose the problem before you go throwing parts at it.
Old Nov 3, 2006 | 11:01 PM
MazdaSilva's Avatar
I figured out the problem guys!
I accidently fliped the trunk switch in the glove compartment and my trunk was disabled. I fliped it back on and everthing is fine now.
I'm gonna have to check the manual cause i don't remember seeing that in there otherwise i would have figured it out.
Thank you for your help guys
chask13
Sep 7, 2024 11:34 AM
pattyd814
Jun 27, 2009 08:35 AM
SilverBirch
Feb 27, 2008 07:28 PM
neitere
May 11, 2006 10:54 PM
mrmiata
Apr 30, 2004 11:00 PM
